2010?? For what I know, this light came at the market here around may 2011Wow....... another Cree XML U2 update for 2010's must have flashlight.
If you want something new checkout the Led Lenser X7R.
It's much more than an LED with an orange peel reflector.
TK41 uses 8* AA
TK41:
860lm
4 x AA
$130
Led Lenser X7R:
500lm
Rechargeable pack
$279
TK41 uses 8* AA
I found this
http://www.fenixlight.com/viewnproduct.asp?id=117
TK41 T6 ....................... TK41 U2
800lm (2h10m) .............. 860lm (2h19m)
335lm (7h15m) .............. 365lm (7h43m)
108lm (27h) .................. 120lm (27h)
10lm (240h) .................. 15lm (240h)
55746cd (max. 472m) ..... 59000cd (max. 486m)
Woah, wait! There's a U3 bin of the XML? Where can I find information on that?
I'm disappointed that Fenix decided to bump the lowest mode from 10 lumens to 15 lumens with the same runtime. I REALLY wish they would have lowered it to something like 3 lumens and gave it a runtime of 400 hours or something insane. That's one reason I really like my PD31. The lowest low is 3 lumens which is great for a camping nightlight or lasts a long time if I need it to.
It is possible the low mode is current controlled and a more efficient emitter has both more output at lower power levels and a lower vf also meaning the current to both emitters is the same as they didn't change the electronics of the light only the emitter.
I think that is what happened.... most likely the 10 -15 lumen bit may not be exactly that much they could be fudging the numbers to have nicer looking ones so instead of it being 11 before and 13.5 now then rounded down to 10 and up to 15.Ah, so they only changed the LED, and not the driver at all during this light upgrade. Gotchya. Shame though.
