Hi there folks.
I have just bought myself an Predator V2.0 and im super happy with it. I only have some questions that i do not hear about to much.
1. How do you remove the button on the new tailcap? There is a spare button but i dont know how to put it in without damaging the button or paint.
2. Is there a new reflector in V2? The OP reflector on v1.2 is much wider spot when i compare them, but both are OP. Looks like mine is 5/24 OP??
3. I would like to put an old button/bezel from v1.2 on my V2 because of the lanard hole on the V2 is to fragile and it wont tailstand, i almost damaged my cigar grip ring after only some few hours use with the lanyard... I dont wont the hole tailcap just the bezel/button from V1.2 cause the tailcap on 1.2 is longer than the V2 tailcap and looks strange if i just switch. Does it fit the threads and stuff?
4. My lens looks much more purple than my buddies v1.2, why?
5. Is the new design as waterproof as the old? The area were you screw the head on looks wery open for dust and water to come in to the threads and not as safe as the 1.2.
