SOLD
Here is a mag mod you don't see everyday. Unique of of kind build, Brighter than XML and with a better beam & longer run time.
Mag 1D shorty but runs on 2x18650 instead of one!
with, thus 2x run time than 18650 mag & 50% more run time than 4000mah 26650 mag without increasing the size!
To achieve this, I removed mag switch & used the Five Mega's new Maclicky Tail Cap for D Mag.
The body tube is JB welded to the head, strong & zero wabble at the neck
6x Cree module (5 modes) has been grind down at bottom & top to fit in mag head perfectly & potted with thermo adhesive for max heat transfer.
Batteries are suspended by dual spring, front & back, which allow flexibility with any 18650, shorter unprotected, or IMR or longer protected all will fit.
Double PVC Battery sleeves with O-ring, no wiggle
Beam is perfect even on white wall, no rings.
Tint is between Cool & neutral, no blu no green no yellow, just white
Price is $169, but there 's a few pin spots on anno here & there, blem, so the price on this light is set at $149
shipping $9 in US. PM me for int. shipping. ----SOLD----
FS is the mag to the right, Mag 2D is in middle for reference
