I took apart my Maelstrom S12 today to blow out some particles in the reflector. I did not touch the lens or reflector as recommended in other threads.
As I was about to re-assemble the bezel/lens, the lens and o-ring fell out. Now I'm not sure which order the o-ring and lens fit inside the bezel ring. Does the o-ring seat between the lens and the bezel ring? or in between the reflector and lens?
I also read that the lens is coated with a scratch resistant coating on ONE side. Is there a way to identify which side that is?
