fadetoblack73
- Joined
- Feb 19, 2009
- Messages
- 30
I am having a problem with my older Fenix PD20 Q5. Normally, I do not use the "Turbo / Strobe" mode. However, this past weekend I needed the Turbo Mode. I tightened the head and out came the full 180 lumens. The problem started when I tried to loosen the head to go back to the normal modes. When I try to loosen the head with the light on and in Turbo, the light simply turns off. I have tried taking the battery out and replacing it with a brand new battery. I have gone through the loosen / tighten routine seemingly hundreds of times. The light is stuck in the high output modes. Any suggestions?
