Imalent
Results 1 to 20 of 20
Thread: Opportunity to buy HDS EDC
    Default Opportunity to buy HDS EDC
    I have an opportunity to buy a HDS EDC BASIC 42 XR, or BASIC 42 XR GT, or ULTIMATE 60 XR torch.
    What do the members recommend as the best choice?
    Thanks
    Hedley
    *Flashaholic* pjandyho's Avatar
    Oct 2003
    Singapore
    Default Re: Opportunity to buy HDS EDC
    Those are production lights by HDS quite many years ago. Although they are very nice lights, they are outdated and superseded by the clicky and rotary. Are you sure you still want to get them? If you do, you always have the choice to get the emitters modded later on to something more efficient.
    The love of light is the reason why I don't walk in darkness. But darkness has it's beauty...Sadly, my lights are much more beautiful!!
    Beam shots Night Trekking with HDS high CRI and McGizmo Haiku & Mule high CRI
    Flashaholic* NoFair's Avatar
    Dec 2004
    Norway
    If you intend to swap out the emitter then a plain U60 is best, cheapest ultimate you can get. Great lights when updated, outdated with their stock lux 3 emitter.
    Feb 2005
    TN
    As the owner of an original HDS Ultimate 60 GT, I'd recommend getting the U60 XR.
    You will appreciate the added run time.
    The run time on Max is 40 minutes, compared to 30 minutes with the U60GT that I have.
    Also, Henry of HDS stated back then that the U60XR was basically the same light as the later U85
    If you are very sensitive to the tint of the beam, and aren't too fussy about run time or overall brightness, then get the GT model. Guaranteed tint, and mine is awesome.
    And the older models you describe are shorter in length than the current models, which I think makes them more easily carry-able.
    The main down-side IMO is that the run times are short compared to more modern lights. They are just older LED technology, but they still do very well if you don't demand the highest light output or long run times. And the run times are pretty decent for the lower brightness levels.
    If you use a 16340 rechargeable lithium-ion battery, you can just recharge it every time you have significant use, and have it fresh and ready for morning. That's what I do. I became tired of using primary cr123 batteries, and having the Max setting run out early, and be saddled with stepped-down output for the rest of the life of the battery. The 16340 rechargeable solved this issue for me.
    Much more convenient to have the Max available when desired, without wasting the remaining life of the battery. Just refresh the charge and have Max again!
    Flashaholic* mossyoak's Avatar
    Dec 2004
    The Southland with a RedBull in one hand and iPhone in the other
    Quote Originally Posted by pjandyho View Post
    Actually, the LED is the only thing outdated. The old series were much more efficient on the lower levels, with runtimes approaching 1 month continuous. The newer versions low runtimes are somewhere around 128 hours.
    And Teeming With Souls Shall It Ever Be.
    NOTICE: I'm a guy. Im to poor to buy cheap.
    Aeon- Smaller, Brighter, Better...
    Flashaholic* Hondo's Avatar
    Oct 2005
    SE Michigan
    Ditto, and to what I think you are asking, the U60 is the one to have, as you can program it with a series of 10 clicks. Note that the Basics can do the same thing, it just takes 250 clicks to enter programming, rather than 10. And that is for each change you want to make. For me, that was just two times in, so my thumb only aches a little.
    About these lights in general, the only "weak link" was the thin aluminum lens retention ring, which won't resist a hard hit on the bezel, and can result in a bent bezel and cracked lens. The most common upgrade for these is a simple swap to a titanium or stainless steel extended bezel ring, which greatly improves their durability.
    Like others are saying, for a user I would (did) upgrade the LED, so there is no reason to pay any extra for the GT model, unless you like the bling of the laser etched letters on the body.
    Oct 2003
    Singapore
    Quote Originally Posted by mossyoak View Post
    Absolutely right. I gave my point above because not many people bother about extreme runtimes and on the other hand most are bothered about max output. I am fine with 60 lumen max but not many are.
    Feb 2005
    TN
    I would add to my previous post by saying that these older HDS lights have pretty decent throw for their power levels. The older LED had a smaller die size, which translates into better throw for the small reflector size.
    My U60 GT will throw a solid 60 yards with enough light left at that distance for me to identify a small animal like a squirrel from a skunk.
    It's pretty good for a little light with only 60 lumens max. Henry did a nice job with these.
    Thanks for all yopuir input. Now I will just have to get the financial advisor (wife) to sign off.
    I knew that they were older lights and not in production but looking at the pictures of them from the seller they are in BNIB condition.
    Also as I am down under in New Zealand they are probably the only ones in the country.
    Thanks
    Hedley
    *Flashaholic* precisionworks's Avatar
    Apr 2007
    Benton Illinois
    Henry is a great guy to work with & he still maintains a good inventory of "legacy" parts. Nice lights, built like a tank. Change the bezel to stainless or titanium & you'll love it.
    http://www.hdssystems.com/?id=LegacyProducts
    Surefire® boring including E-Series & Weapon Lights* Please text msg, phone or email through contact page at https://precisionelectrical.us/
    Aug 2006
    SF East bay Ca
    These lights the EDC series are before the Legacy lights and parts are not enter changeable. The bezels from the Novatac lights are the same.
    Apr 2007
    Benton Illinois
    Quote Originally Posted by wrencher View Post
    ... the EDC series are before the Legacy lights and parts are not enter changeable.
    Legacy is neither a model nor a series of lights. Legacy products refer to lights that Henry made in the past. The EDC BASIC 42 XR, BASIC 42 XR GT & ULTIMATE 60 XR are all Legacy products for which many parts are still available. Click on the link in post #10 to see the entire family of Legacy products.
    Dec 2004
    Quote Originally Posted by precisionworks View Post
    It was my understanding that the "legacy" lights were the Ra and HDS that look like the current models but don't have Acme threads. It was to differentiate so people didn't buy acme threaded stuff for v-sharp lights.
    Aug 2006
    SF East bay Ca
    EDC parts only fit those lights. When he sold his business to Novatac all the spair parts went with the sale. I have had a EDC U60 in for repair and he didn't have any parts for the repair. So I was offered a credit toward a new light. Witch is why I will always be a HDS customer.
    Quote Originally Posted by twl View Post
    +1! The elusive XR would be my vote. The reflectors work great with any of the modern emitters.
    Apr 2007
    Benton Illinois
    According to Henry (as shown on his website) the Legacy products include all these:
    The list in in chronological order & the Ra/EDC Twisty & Ra/EDC Clicky are the newest lights that are no longer in production.
    Aug 2006
    SF East bay Ca
    As someone who has owned a EDC Basic and EDC Ultimate lights I can assure you the parts do not enter change. I also own the Ra Clicky and Twisty and they have a different body. The same body as the current lights but different thread. Yes the the discontuned lights are all legacy lights.
    Dec 2004
    The basic, and ultimate lights will most definately interchange. the only difference is how they are programmed.
    the Twisty and Clicky lights are completely different.
    Aug 2006
    SF East bay Ca
    My bad I ment EDC parts will not interchange with later lights.
    Thanks for all the advice.Pulled the trigger and got it. Now the proud owner of a mint condition EDC Ultimate 60 XR #3985. It is in perfect condition and is working just fine. CheersHedley
