Imalent
Page 1 of 3 123 LastLast
Results 1 to 30 of 70
Thread: FS: Vintage Ray-O-Vac XM-L U2 Mod (1000 Lumen)
    Cool FS: Vintage Ray-O-Vac XM-L U3 Mod (1000 Lumen)
    These are nice vintage chrome hosts for an XM-L U3 1000 lumen mod...
    Note: I'm now using the new XM-L U3 emitters because they are better, but can use any emitter you would like... (U3 1C on hand)
    I also have the new XML-2 emitters by request...
    --- Retro / High Tech ---
    Ray-O-Vac made this 2D 'Sportsman' model in 1965.
    I have several of these in mint condition with box.
    If you want a $20 dollar discount, I have several used hosts in good condition. (some signs of wear, but in good condition)
    In this modification, I am gluing a 'plug' inside the host, and using a single 32650 Li-Ion supply. (I have fiberglass sleeves for a 26650 as well - $5)
    Features of the build:
    * XM-L emitter
    * Multi mode 3 Amp driver with memory (see notes below)
    * Sized for a single 32650 Li-Ion supply
    * Multi-Layer Coated HD Glass Lens with custom sized silicone o-ring (or glow ring option available)
    * Aluminum reflector (chose smooth or MOP - see below)
    * Glow ring option
    Notes:
    * This is a 'fixed focus' design. I will have it adjusted to best spot. It has a nice bright spill area. 'Best spot' focus is the preferred set up...
    * This driver uses 380mA AMC7135 chips to reach 3 Amps. It has many modes that can be configured. I personally like the 2 mode set up. (medium and high)
    * I have 6000mAh 32650's here!
    See here for some feedback from some who have bought this build...
    More about the driver:
    The driver is 8 X AMC7135 chips, but the new V2 driver uses 380mA chips vs 350mA chips normally.
    So it puts out 3 Amps...
    I personally like the 2 mode configuration. But I can configure the driver how ever you would like it per this configuration sheet:
    The pictures show the details of the build...
    Multi-Layer Coated HD Glass lens (Glow ring is an option)
    The glow ring is custom made by Fiddy...
    Aluminum Reflector: (choose smooth or MOP)
    Smooth reflector...
    MOP reflector...
    Beam shots:
    Current readings (2 mode configuration): (High, medium)
    Pretty much the same at the emitter as measured at the tail: (linear driver)
    Measured at the tail: (battery current draw from a single, 6000mAh 32650 Li-Ion)
    * High - 3020mA's... Estimated run time - 2 hours!
    * Medium - 890mA's... Estimated run time - Over 6 hours at about 320 lumens!
    Pricing:
    This build could be cheaper but I'm using the best parts I could find since it's such a great vintage host!
    The complete build will include:
    * Ray-O-Vac Sportsman host (Mint condition with box)
    * Heatsink/driver/XM-L U3 emitter installed and tested (let me know desired mode configuration for the driver)
    * Aluminum reflector (specify smooth or MOP)
    * Assembled and ready for your battery
    $199
    Options:
    * 6000mAh 32650 cells - $24 each
    * Custom glow ring - $15
    * Discount: Used host/good condition - Subtract $20
    * If you need a battery and/or charger with your order, just let me know and I can include those items as well...
    Shipping will be based on transfer fees plus postage... (PM me for total)
    Shipping Policy
    Hope you like it!
    Flashaholic* jmpaul320's Avatar
    Mar 2012
    CT, USA
    Default
    Another cool creation from jayrob!
    Moderator
    Dec 2008
    Penn's Woods
    Default Re: FS: Vintage Ray-O-Vac XM-L U2 Mod (1000 Lumen)
    Now that's cool...
    Glad you guys like it!
    I'll be using this post for quoting feedback from buyers...
    I Love to see good feedback. Here's the start of some buyer feedback on this build. So that I can link to it from other sites...
    Quote Originally Posted by CMAG View Post
    Got my light from Jayrob she is sweet
    ...All of jayrob's builds are sweet have his ican and led mags and now this classic
    Quote Originally Posted by helios View Post
    Hi Jayrob,
    Received my light two days ago but I've been working nights so I couldn't post. The light arrived in perfect condition and much sooner than I expected, thanks!
    I'm a police officer working the 8PM to 8AM shift so I guess I have the ideal job for testing flashlights. I use a Thrunight Catapult as a primary light. It produces a fairly massive wall of light and your build produces just as much light but in a smaller package with a better driver. And its just so pretty. In fact, I'm afraid to dent it or scratch it.
    I've received numerous comments from co-workers like "hey, I had one these when I was a kid" or "that's the coolest flashlight I've ever seen" or "wow, that's bright!"
    Thanks again for the very fast shipping and the out-of-this-world cool factor!
    Gordon
    Quote Originally Posted by ZeissOEM2 View Post
    The light arrived yesterday.
    Very great . Thanks
    Best regards O.R
    Quote Originally Posted by CLong
    Thanks so much Jay! This is an amazing build you have done. My husband is going to love his anniversary present.
    Quote Originally Posted by Brett
    Jay, I'm so happy I got this light from you. Thanks very much for building it for me!
    Quote Originally Posted by Halibut View Post
    Received my Ray-O-Vac mod today. FANTASTIC job. Fit and finish are superb, and the light simply looks awesome, in that special old-timey way. Thanks again for the quick turnaround and customizations!
    -Dan
    Quote Originally Posted by LaserEddie
    Received two vintage builds from JayRob: The Ray-O-Vac Sportsman and the Eveready brass with beveled glass lens. When I put the Ray-O-Vac on "high," Mamma Mia! The thing lights up the room enough to give you a sunburn! I call these my DEU's (Dark Extraction Units). I have a Cyclops 30 million candlepower spotlight (incandescent, with a big battery), and this equals that monster. The brass Eveready is the same, with incredible throw. I really love these lights - taking nothing away from the Maglight builds, but these are real sleepers, and look awesome in their vintage splendor. It's so nice to have the security of lighting up a dark alley like it was daytime. I shudder to think of what these single-emitter fire-breathers will bring in the future: 10,000 lumens? Pulling one amp? Runtime: 100 hours? Lol! The future is BRIGHT!
    Thanks Jay, for these super builds. GO VINTAGE!
    Quote Originally Posted by Sanford02 View Post
    I received my rayovac a few days ago, and I love it. I like this one a little better than the everready, but that's just because I think the host looks cooler. In this one I have a nice cool white XML-2. Very bright, smooth beam.
    nice work jayrob!
    Like it
    I will take it
    PM on the way
    Pay Pal Sent
    Like it
    I will take it
    PM on the way
    Pay Pal Sent
    Got you covered...
    Flashaholic* tobrien's Avatar
    Dec 2005
    Georgia Highway 441
    NICE! By vintage for the body, do you mean it really is old or just a newish body designed in the old style?
    They are old lights. But collectors have kept them. I have gathered a few...
    I have several 'mint condition with box' hosts!
    Or for a $20 dollar discount on the build, I also have several 'used but in good condition'. Obviously some signs of normal wear and so forth, but good condition hosts...
    Flashaholic* TORCH_BOY's Avatar
    Jan 2004
    Australia, Vic
    Nice light.
    Quote Originally Posted by TORCH_BOY View Post
    Nice light.
    Thanks!
    I love it...
    It's nearly 50 years old!
    Aug 2010
    ROLL TIDE!
    Thumbs up Re: FS: Vintage Ray-O-Vac XM-L U2 Mod (1000 Lumen)
    Wassup Jayrob? Now why didn't you post this a day earlier??? I just bought a 1962-62' Eveready Captain with plans to do something similar to it. I'm kinda lazy (and you could do a much better job than me I'm sure) so maybe I could send it to you for upgrades?
    PM me if interested. Either way, good luck with your sales. I'm sure they'll go quick.
    SPY 007 XM-L2, BVH 150w Vec192 HID, Gen III Maxabeam, Barn Burner, FireFoxes III & IV, Mac's Customs 3840L & Damascus/Cu/Al Tri-EDCs, ma_sha1 FrankenMag, Drake, MF Scorpion 4x XM-L2, Tri-219 EYE10, XP-G2 X10
    I think you did your math wrong on the low mode runtime.
    Quote Originally Posted by hellokitty[hk] View Post
    Hmmm... Well keep in mind that the current measurements were taken with a fully charged battery as well. So the run times are 'estimated run times'. But with 6000mAh's supply capacity, divided by 150mA's, it's 40 hours... (150mA's battery current draw on low power)
    Edit: I'm recommending a 2 mode setting these days anyway.(medium and high) Because low is only 5% and pretty dim...
    Quote Originally Posted by Colonel Sanders View Post
    Nice!
    Sure I can take a look at it if you want...
    The only thing really, is as long as the head fits the reflector that I am using. Or if we can find one that fits.
    I'm doing some light machine work on the KD aluminum Mag reflectors to fit them to this Ray-O-Vac mod.
    The only other thing that needs to work, is the switch, and we're good to go!
    Send me a PM!
    Additional PP sent
    The lot of 4 over on CPFMP
    Dec 2005
    Georgia Highway 441
    i have to buy one of these when I get the funds
    people will be like, "wow cool old light you've.... AHHHHHHHHHH MY EYES"
    Just let me know when your ready!
    Dec 2008
    Maryland
    This is a really nice upgrade for a classic light. I really admire your work! hope to come up with the funds to have you build one for me soon.
    Unenlightened
    Aug 2012
    In God's country, (Alabama)
    Man that is awesome!!! I remember these from when I was a kid. My dad had these around the house all the time.
    it was also carried by many police back in the 60's and 70's as well.
    i sure hope you can keep doing these untill I can come up with the funds to buy one.
    I should have them!
    Just let me know when your ready...
    Quote Originally Posted by briteflite View Post
    Will do!
    At the moment, I have several mint condition lights with box. And also 7 or 8 that are used but in good condition...
    I'll be keeping my eye out for more of these lights though.
    They are a really nice host!
    Flashaholic Megatrowned's Avatar
    Jun 2012
    Wisconsin
    I sold one of those lights at a garage sale last year If I had only waited... That's it. I'm never getting rid of Anything ever again
    Quote Originally Posted by Megatrowned View Post
    Now you can get it back!
    (modified of course)
    Unenlightened
    Apr 2012
    I like it Jay!
    I still love the light you made me.
    Banned
    Jun 2012
    Tucson, Az
    How much for a mint host?
    Well at this time I'm still in the market to keep collecting the Mint hosts myself! (for this build that I'm offering)
    So at this time, I really do not want to sell the host by itself if that is what you are asking...
    Hope to build you up one of these mods though!
    Quote Originally Posted by FyreLyter View Post
    I like it Jay!
    Glad to hear it!
    Love to hear good feedback...
    Banned
    Jun 2012
    Tucson, Az
    Quote Originally Posted by jayrob View Post
    Glad to hear it!
    Well, I am sorry to hear that
    I guess I'll just keep $AVING UP
    Quote Originally Posted by Empire View Post
    Yeah I'm looking to buy mint hosts specifically for this mod...
    Retro / high tech - it really is a cool build. Which is why I decided to go for the nice parts as shown.
    I could have made it cheaper, but I really felt that the host deserves the good parts. (aluminum reflector, glow ring option, coated glass lens, etc...)
    Flashaholic* ZeissOEM2's Avatar
    Jan 2005
    Norway
    I am interest in one with battery and charger
    PM in coming...
    I just got word, and ordered new stock of the Feilong 6000mAh 32650 cells. (they are the best! - tested here)
