I recently picked up an E2L (KX2 head) from Ebay. Think I got a pretty good deal at £29... very impressed with the color and beam pattern.
However, the clicky tailcap is broken. Only way to activate the light is to tighten both ends, then the clicky has no effect. The contacts in the cap had ended up at the wrong end, so it wouldn't screw on more than one turn. The I've taken it apart and fixed this so it screws on all the way but the clicky is still dead.
Am I correct that this should be a two-mode light?
Is there a replacement clicky I can buy? Any advice would be appreciated.
