Coup de Grace
I am offering to you a Sunwayman V10R Ti+. It is near mint condition. Just about new. Installed is a delrin retaining ring for super smooth button action. As you can see in the picture, a Ti AA is installed allowing the use of a AA battery.
All orIginal accessories including the care package that has titanium polish, extra screws and polishing cloth. There's a holster as well among other items. The original Ti retaining ring is included as well for that all Ti look.
Here's the manufacterer's specs:
Continuously Variable output 1-500 Lumens w/16340 Cell (NOTE: Do not run the light continuously at turbo mode [500 lumens] for more than 5 minutes.)
190 lumen max with alternative battery options
Length: 3.3" (84.5mm)
Weight (w/o Battery): 71.8g (71.8g)
CREE XM-L U2 LED, with a lifetime of up to 50,000 hours
Digital Sensor Magnetic Control system - Slightly twist the Rotator Ring from left to right for Min to Max output
Constant current circuit, constant output
Effective range of 130 meters
Uses one single CR123A (RCR123A/16340) battery
Working voltage: 0.9~4.2V
High quality OP reflector maintains great throw distance and spread with an ideal beam pattern
High-grade Titanium alloy
Waterproof, in accordance with IPX-8 standard
Ultra-clear tempered glass lens resists scratches and impacts
Tactical forward click switch with momentary on
Tail stand capable- can be used as a candle
Accessories: Clip, O-ring, rubber cap, lanyard, holster, and rubber tailcap switch
Here are the pics:
Asking $200.
Here are the pics:
Asking $200.
