Sale Closed.
For sale are four single level Aleph light engines. The three CREE XM-L light engines use use a custom circuit board with four AMC7135 IC's at 380mA each. The single level Nichia 219 Aleph light engine uses a custom circuit board with three AMC7135 IC's at 350mA each. The aluminum can was custom machined for the 8mm MCPCB, and dissipates heat quickly into the head of the light. These are ideal for use with a single Li-Ion cell (or 6V maximum). Brass battery contact for long wear.
These light engines will work in all Aleph lights. However, some slight modification of the reflector may be required when used with a Luxeon reflector to achieve a perfect focus. These light engines focus perfectly in a Seoul reflector, or a Luxeon reflector with 0.030" removed from the LED side. An LED that is positioned just behind the reflector focal point will create a slightly floodier beam. When used with an XR19 reflector, the LED will need to be slightly behind the reflector to achieve the ideal focal point. I will modify your Luxeon reflector on my lathe at no additional charge if you send the reflector prior to shipment of the LED module.
1. CREE U2 2S XM-L, 1520mA single level light engine. $89
2. CREE U2 2S XM-L, 1520mA single level light engine. $89
3. CREE U2 2S XM-L, 1520mA single level light engine. $89 SOLD
4. Nichia NVSL219-H1, 4500K, 1050mA single level light engine. $91 SOLD
Note: Light engines now include white nylon shield for LED, to prevent short circuit contact with reflector.
Will trade a light engine for a complete Pierce M10i kit (with both optics and original pill bottle), or mint Pierce M10.
The first "I'll take it" posted here takes preference over other communication. All prices include shipping within the United States. There is no extra fee for credit card PayPal. Insurance is not included, but is available upon request for an additional fee based on insured value. I can not be liable for damage or loss once the light engine is in the hands of the USPS.
Thanks for looking
Thanks for looking
