Zebralight SC51 keychain attachment?
KirthGersen
Is there any way to attack a Zebralight SC51 to a keychain? I've tried searching but haven't been able to figure out an answer. Thanks a lot. It seems like a keyring attachment could at least be mounted to the two small screws, but I haven't found anything.
think2x
Pulaski, Va.
I made a couple out of SS when I had my SC31w but no longer have a light to use for fitment to make any more. It can be done fairly easily if you are handy with basic tools and a dremel.
KirthGersen
Ooh, that's pretty. I will have to get a dremel and some basic tools (not to mention skills) sometime. What tools did you use besides the dremel, if you don't mind my asking?
think2x
Pulaski, Va.
Drill
Dremel
Flat File
Digital calipers (to measure a little more precisely for the hole spacing)
A Vice (to clamp the part in so the slight bend can be put in it)
Hammer (to do the bending)
Polishing Compound
90 Minutes
and the main part...................one 1-1/4" diameter SS fender washer.
