FloridaGuy
- Joined
- Apr 8, 2007
- Messages
- 36
It is my understanding that many people use 3.7 volt RCR123A batteries successfully in their Quark Mini ML-X's. Will a user still be able to access all three light levels when using these batteries or will it only run on high at that point? Will those lower levels be proportionally brighter than with a standard disposable 123A battery? It would seem like the brightness would be a max of 3.7V/3.0V=1.23 or 23% brighter than with a three volt battery (on all modes) but I've seen some claims that would make it appear to be far more significant than that. Is that true and, if so, is that because it is not regulated at the higher voltage?
