I have a brand new Xeno G42 V2 and it is exhibiting an issue. I use this flashlight with 1x18650 protected LiOn battery. I have not tested with 2xCR123 cells.
After about 30 minutes of use (rough estimate) the flashlight does not operate at its highest brightness. This occurs when the battery still has lots of life in it. Not a problem. What is a problem is that I cannot get the flashlight to operate at its lowest brightness, either. Only the middle brightness works.
This issue is not 100% reproducible. If I mash the switch ten, twenty, or thirty times, I might be able to get the lowest brightness to occur.
This is very irritating. I am most likely to use the lowest brightness precisely when the battery is low. This Xeno is the most expensive light I have purchased so far. I expect more.
Has anyone else experienced this issue? I would like to know how common this behavior is. I have to decide whether I should ask for a repair from Xeno.
