Hi - I've been lurking here over the weekend trying to learn some electronics (I'm a mechanical engineer, so electronics is still in the "magic" category for me at the moment....), any you guys look like you know your stuff
I've got 2 old (2008) SpiderFire torches [http://www.tactical4u.com/en/product/item/238/product_detail.html]
that I'd like to boost the output on. I've been having a good rummage around the forums and I think I know what to do, but I wanted to run it past some people who really know what they are doing first!
I dug out my multimeter, so I'll start with some measurements: Batteries are 2x Ansmann 2800mAh NiMH AA's, giving 2.6V when fully charged.
Emitter is a Cree Q5 (XP-G?). Measuring across the LED (which I assume is ok across the red/black leads from the driver), I get about 2.9-2.95V when lit.
Measuring "at the tail cap" (I assume where the cap will contact - across rear of battery to housing) I get 0.47A when lit. Its just a basic on/off cap, so the driver must be a 1 mode thing.
They normally run for 3.5 hrs on full and then get dimmer until about 5 hrs. So I think if the battery power is (2 x 2800mAh x 1.2V) = 6.72W, then that matches the LED requirement; 6.72W / (2.95V x 470mA) = 4.84 hrs.
So these were my questions:
1. Is the driver regulating the voltage (batteries give 2.6V, but its 2.95V across the LED)?
2. Can I swap the Q5 directly for a XM-L T6 and get something like a 280% increase in brightness? If the driver is voltage regulated, and both LED's seem to have the same forward voltage, then it should pull the same current. So that would be nearly 3x the brightness for the same battery life. Sounds a bit to good to be true would it work?
I know I could by a T6 light off the web for no money, but thats not the point is it? Thanks in advance for the help!
