Joe Talmadge
I stuck a 16340 in my XT1C before I realized only CR123s were supported, and the thing lit up super bright, got hot quick -- but did not burn out the circuit. So I sent an email to Klarus about whether they are supporting only CR123s because of circuit limitations, or because of the heat, and the answer is ... the heat. You can evidently use 16340s, just turn the thing down when it gets hot:
I've heard a lot of people say they'd get an XT1C if they could run 16340s. Well, this isn't exactly carte blanche, but with caveats, you can run them.
Dear Joe,
Thanks for your inquiry.
XT1C Max working voltage is 4.2V, any batteries winthin 4.2V are workable.
You can use RCR123 battery, just use is will gets too hot, but I'm recommend you don't make high model more than 5mins.
