Random Dan
- Joined
- Jun 30, 2012
- Messages
- 1,371
Contemplating the purchase of an Olight S10 Baton, but nowhere can I find how the UI works. Could someone who knows how it works help me out? Thanks.
Thanks! I guessed it was something like that, but I wasn't sure.From what I understand:
To Turn On: Quick Press while off
To Turn Off: Quick Press while on
Mode Changing: Press and hold while on; cycle will be from low-med-high-med-low (with mode memory)
Strobe: Double click while the light is on
Moonlight: Press and hold while the light is off
The S10 will not have electronic lockout. Hope this helps.
I don't think it will be an issue if it is anything like the other lights in the Baton Series. Granted I haven't pocket carried any of the lights, but they require a bit more force to turn on than the SC51. I'd say the button is comfortably in the middle between the SC51 and SC80. Of course, time and trial use will tell.How stiff is the button?
I noticed from the pictures it looks like the button protrudes? Is it going to be like the Zebralight SC51 which is unusable for pocket carry without lockout due to accidental activation? or is the button stiff like the SC80 so lockout is unnecessary as it is very unlikely to accidentally activate during pocket carry?
This is sad. Hopefully, in s20 (if it comes) will be different."If flashlight will turn on med mode, how do i know which mode next, lo or hi? :thinking:"
this is memorized too, you have to remember.
