Landshark99
Looking to add one more 2000 plus Lumens light to the collection. I already have a TM11 and a TN31, so I guess I am looking for something in between those two
I may be wrong but I thought the T60CS was slightly newer than TN30
The T60CS has 34,100 Lux in throw. (imperceptible throw difference compared to Catapult V1!) TN30 is 49,300 lux. I find anything over 25-30K lux not needed in the real world unless you're using a scope/binoculars. 34,000 lux is a solid 250 meter light, with reasonable light to 300 meters IMHO. I Much prefer the wider beam of the T60. The beam appears to be better also. I doubt you'll notice the Lumen difference between T60CS/TN30 (2300 vs 2750) In fact....you'll have a hard time seeing the difference between "Turbo" and "High". Some people have asked if their light is defective because they can't see a change. The real measured change from Turbo to H is 2300/1900. I can see it, but you have to switch many times and study hard.
The T60CS is also a much handier size light. TN30 is 1.35" longer and has a .2" larger diameter grip. It's just too big in my opinion. T60CS is only about .4" longer than the TM11, but again has a smaller grip. 3 batts are enough. I also like the side switch much better than the combination ring and tailcap switch for TN30. I think the charging base is a plus on the T60CS. I don't want to remove/replace batts into those carriers all the time. Plus I don't want to buy a 4 lane charger, or charge the batteries in two seperate runs with a 2 lane charger. It is my first SWM and I am impressed. This is an awesome flashlight.
Then remove the Lanyard. How long does it take to remove the lanyard clip? More than a second or two? I have no doubt it's still faster than removing the batteries/carrier for charging.
No word on charger port plastic insert as far as I know.
What does everyone think about the T60CS regarding the different power levels, the spacing, usefulness, etc..?
What would you change about the T60CS?
that action would be obvious if I was using a lanyard with a clip. The lanyard supplied with most lights is too long for my carry habits and I do not use them.... I routinely use a 6" wrist lanyard which has a small threaded loop similar to those on P&S cameras, etc. Why? Because I have a way of wrapping the wrist lanyard loop around my hand such that it is firmly held in my hand in case I lose my footing whereupon the light would otherwise be clattering on the rocks or concrete floor with the longer supplied lanyard. Also, if my hands are suddenly 'full', I can "drop" the light and it dangles not far from my wrist - which gives light reflected from the ground/floor yet the light is still w/in "reach". Ergo, my problem with the SWM charger is just that, my problem.
edit: Look at the Lighthound website for lanyards. it is the 6" wrist lanyard. LH has those in GITD and black, although the GITD effect is a bit weak.
I just got my T60CS yesterday, but so far I'm EXTREMELY Impressed. This is my 6th or 7th SWM, and they are all awesome. The power levels/spacing is good. I honestly expected a bigger difference between the 2100 lumen Turbo and the 1680 Lumen High, but I guess perceived brightness is more logarithmic and you can't notice 400 lumens that high up as easily as you can on a less powerful light. I feel the low is low enough for most tasks, and the spacing overall is decent. I wouldn't hesitate go go with the T60CS. Others mention the charger base having issues with a lanyard, but there are two easy fixes for that...either take a Dremel and notch out the charger base, or just don't use a lanyard...it has a holster which is useful, and honestly the light isn't so huge you can't carry it on a holster (mind, it's not an EDC).
