The Sunway V20C may not be too popular because it:
(1) is not a 16340/18350 size light, which is most pocketable, hence most popular for edc.
(2) the infinite ring control is not critical on a more medium or small-medium sized flashlight; infinite control is more important in smaller 16340/18350 sized lights which are used more for short distances and indoors.
(3) the V20C's balanced flood/throw beam is not as popular as the pure flood lateral spill beams.
(4) the V20C doesn't pack as many lumens as competitors eg it packs only some 460 or 500 lumens, where the ZL SC600 packs 750 lumens.
(5) the V20C looks a bit bland compared to the SC600; but very personal comment though.
The greatest competitor for the Sunway V20C is probably the Zebralight SC600.
The SC600 has a side clicky only, so it is a short 107mm long, and continuous adjustment is generally not in great demand for this size of flashlight.
The SC600 has a pure practical flood beam, with less throw than the V20C.
The SC600 outputs 750 lumens, which is about 1.5 times more than the V20C.
The V20C has a lot of catching up to do.
The V10 and V11 lights are popular because:
(1) compact 16340 size,
(2) infinite continuous ring control adjustments, while the ZL SC80 has a side clicky for 3/6 levels of brightness only.
(3) XP-G and XM-L emitters available, where the Zebralight SC80 only uses an old XP-G emitter with a tiny hot spot.
(4) the V's have style, where the SC80 looks quite bland; the SC80 needs to be quickly replaced by an SC800 XM-L....
