Hi flashlight enthusiasts,
I just finished up my latest creation. I have been wanting to get this going for a while I just hadn't made the time to do it until now.
The first thing I did was to select a switch capable of doing the job. There are a lot of push button switches out there but not with a high enough load capacity that will fit in the tail of a D Maglite.
A McClickie would have been the easiest choice, but these switches are really not built to do what I need them to do. Dont get me wrong, for small lights they are very robust, but the resistance in them is fairly high and I dont like the size of the spring VS a 26650 or D cell.
I ordered a whole spread of the Judco switches and tried a few of them out including the forward click one. Sadly the only way to get a good feel out of that one would be with a raised switch boot ( Yes Techjunkie, I know you told me so), there is just too much travel on that switch. It was like trying to stick your thumb down far enough to touch your wrist or something, just not a good feeling:shakehead.
After a quick look at the others the field narrowed rapidly to the stumpy 10A reverse click. Its small, heavy duty and has a very short travel.
The next step was to bore out the tail cap to fit the mag switch boot.
I used the factory boot so the light will still be able to tail stand when it is done.
Next I needed to make a housing to support the boot and hold the new switch. Delrin is the preferred material. Ahh if only everything machined like this stuff.
Here's what she looks like all nestled into place.
That little part looks fairly simple but man is there a lot of steps and changeovers to get all the little angles and cuts made in that thing.:toilet:
Now we need a second piece to hold the spring. All we have to do for this is pop the lid off a film canister.
LOL.... A film canister.. YEAH RIGHT! Seriously though more cutting, change overs and steps. Fortunately I have my QCTP to ease the pain .
Here is the final product.
Now it's time to make a host.
Oddly enough the place to start here is with the knurl pattern. I thought about it and didn't see any way to get what I wanted from a 2D so I jumped to a 3D.
Doing the tail switch mod means having to cut and re-thread the light from both ends anyway so I figured I might as well get the look I want too.
A plug is needed at the other end where the old switch was, so acetyl and copper it is.
A groove is then cut for a snap ring to sit above to hold it in place.
Here is the little guy all finished up.
VS a 2D Mag.
EDIT: After posting this I have heard numerous comments about wanting a C size so I decided to go ahead and detail a few other options.
Here is what the C will look like.
I'll offer thees for sale here
Let's hear your thoughts on this guys..!
VS a 2D Mag.
