Yes I had two X3T binned 5W HDs, and one of them is on auction right now in a Space (make that Super) Needle. But the other I stuck in a PR head Don sent me and ran it through a BB750. Nice output, but still no brighter than any regular Bin Coded 5W due to the regulation constraints of the BB750.
While sitting in my workshop puffing away on a nice La Gloria Charlemagne, I was turning the 2-cell McLux tailpack over and over in my hands until I tried dropping in three CR2s. They fit. Normally CR2s are like $6 or $7 apiece at Wal-Mart, so a Direct Drive mod using them would not be that cost effective. But with Battery Station now selling their DP-branded version for a buck-quarter each, I figured what the heck -- and I gutted the PR head of its BB750 and wired everything up as Direct Drive, with a RAM switch installed in the tail. Hey, way brighter. WAAAAAY Brighter!
Then the unthinkable happened -- the light started flickering, and I pressed the Ram switch on and off a couple times and it started off okay again, then flickered again, then finally stopped working altogether! Oh, NO! My beloved X3T!!!
I took everything apart and checked for continuity/shorting in the wiring and solder joints and stuff, and all was okay. Hit the precious X3T with 6V from the power supply and it lit up nice and bright. Soooo -- I checked continuity in the RAM switch and...THAT was the culprit. It had toasted out!
Stuck in a good ol' reliable Kroll and all was fine again. Whew...
Here it is soaking up some Hawaiian sun next to its cousin, a Space Needle II with the new VXOW 5W HD emitter (Thanks Howie!):
Then the obligatory beamshot (X3T DD McLux-PR still on the right):
Just to be fair, the Space Needle II's beam focus was adjusted out slightly to approximate the size of the X3T's. Still not that fair a comparison as the Space Needle had fresh 123s while the X3T had to make do with some half-used CR2's until I get my shipment of 50 of those $1.25 ones from Kevin.
And yet the lux reading with those half-spent CR2's was still:
I feel this light would easily break 3,000 lux once I get fresh batteries in it (they tested at around 2.95V each). With McGizmo's installed cell-clip and the overall smooth-beamed high brightness from the excellent Pelican reflector, this X3T McLux-PR has now become my EDC. For a few days anyway, until I grow tired of it and -- auction it off...
Thanks for reading!
Thanks for reading!
