waywardgeek
- Joined
- Sep 29, 2012
- Messages
- 28
EDIT: The Klarus MiX6 is apparently a design created by Foursevens and stolen by Klarus. I'll remove this edit if I can get better information about what really happened, and it turns out that Klarus did no such underhanded thing, but until then, I assume Klarus stole the Preon Revo design. I can't support anyone buying a stolen design. My original review follows...
The Fenix LD01 (the black flashlight) is a fantastic single AAA LED flashlight. Some consider the R4 version the best available AAA flashlight at any price. The Klarus MiX6 (the gold flashlight), in comparison, has been panned by some reviewers. I own both. Of the two, the Klarus MiX6 is the one I carry.
I had the Fenix first, and was quite attached to it, so when the Klarus arrived, I was skeptical. However, after carrying the Klarus for a few days, I was shocked at how large the Fenix seemed when I picked it up. The Fenix LD01 is a tank.
One reviewer said the Klarus didn't feel smaller because it's nearly as long as the Fenix. I suspect this reviewer did not carry the Klarus for long, and made that decision without gettin a feel for it. Not only is it 4.4mm shorter, but you don't feel the tail lanyard while holding it, making it feel more like 8mm shorter. More importantly, it's 2.4mm narrower. The shocking part about picking up the Fenix after carrying the Klarus is how wide the Fenix feels. Here's a closer look at the tails. The Fenix does tail standing well, but it feels as long as the lanyard portion.
Much has been said about the superior beam of the Fenix. Granted, it's a tad bit nicer. It's slightly brighter, and lasts slightly longer. However, both are current and temperature controlled, and the difference in performance is sight.
The Fenix has a wider, deeper reflector. The reflector on the Klarus is about as wide as a Maglite Solitaire. That larger reflector is nice, but comes at the cost of increased size.
The Fenix is so much wider, the Klarus can fit inside it.
The Klarus is beautiful. It feels better in my hand. It functions nearly as well. There is no question that the Klarus is the one I will carry, so long as it doesn't break!
Here's the nasty part about the Klarus:
Actually, that's an Eastern Hognose snake I found in my driveway. It flattens it's head when scared.
When dropped, the Klarus flattens it's tail spring... permanently. I'll do this mod if/when I flatten the tail spring. That's a very unfortunate downside to this light, and the main reason people seem to dislike it. The other complaints I find mostly unwarranted. There's nothing wrong with male threads on the head. I prefer it to the Fenix female threads. The Klarus is not be a "battery crusher", at least until I make the mod. Feel free to crank down the head hard. That's what the faulty tail spring is for: to let you crank all the way down without crushing the battery. The head is not likely to fall off and get lost as suggested in one review.
All in all, the physical design of the Klarus is far superior to the Fenix. That makes it a joy to carry. It's beautiful by comparison and feels better in my hand. These issues matter. Why no one seems to get a AAA completely right is beyond me. Here are the two things that need to be done to make both the Klarus and the Fenix great lights:
- Allow 10440 LiON rechargable batteries to be used, which would double runtime, and increase brightness.
- Turn off when the head is tightened, and as I unscrew it, start dim and get brighter. Don't make me fiddle with modes by screwing back and forth.
All in all, both are great lights. If Fenix did a Klarus stainless knock-off, with these two improvements, they'd own the AAA flashlight market, at least the high-end. Until then, the Klarus will be my main EDC light.
