For those that like strobe (and I do not wish to derail this thread into a discussion over whether we should or not, let's just accept that some do, some don't), the Quarks with the XP-G2 emitter have a much better (14-15 Hz I believe) strobe rate than the ones with the XM-L2 emitter (10 Hz). This is a bit surprising given that Klarus and perhaps others seem to achieve higher (14+ Hz if I recall correctly) strobe rates with XM-L emitters.
Also, most of the Quarks with XM-L2 emitters have burst mode, which many here like, but for which the affect on battery life needs to be considered. If you use your light intermittently for short periods of time, it will always be operating in burst mode for most or all of the time, which will cut your battery life approximately in half.
Many people, including me, are quite happy with the Quark Tacticals with the XP-G2 emitters, finding that they have plenty of output. All of the FourSevens lights I own (including Mini and Preon lights) have XP-G or XP-G2 emitters, and I am quite happy with them.
