I'm late to the Powertac party
Lou Minescence
New England US
I just noticed Powertac flashlights for sale . Then I noticed some models look identical to some Thrunites.
Did another Chinese manufacturer realize they just need their customers designs to start selling their own flashlights and make money ?
Ezeriel
their 2aa light looks a lot like a shiningbeam spark...
...at twice the price :ohgeez:
moshow9
El Paso
The E3 looks and functions exactly like Thrunite's Ti, and the T1C is shaped just like the Neutron 1C, although the T1C has a different UI and momentary (Specs say reverse clicky but this youtube video shows momentary: http://www.youtube.com/watch?v=dLQNekYg5Zc).
officermartinez
Hey guys.. I'm considering Powertac as a duty light. I'm also considering Powertac's 2100 monster light. Is this light basically the same as the Olight SR90?
Bwolcott
California
their are a couple manufactures in China that make a lot of these lights for all the different brands, and sometimes they just rename the light as another brand
officermartinez
Thanks everyone for the input. One thing that Powertac told me is their 2100 lumen version is called the Powertac Destroyer and it has a cooling fan built into the unit to help prevent overheating.. Anyone have any input on that?
Bwolcott
California
Ive never seen their light called the destroyer? where did you see it they dont have it on their website
officermartinez
Here's a picture of it. Since Powertac is a spin off from Olight, I believe it may be similar to the SR90 or possibly the SR95 in size, output and features.
(Thanks Norm for squaring me away. Issue resolved)
Bwolcott
California
they actually arent a spin off of Olight, I thought they were originally but what it is, is the owner of Olightusa ( just a dealer that sells Olight) started Powertac, that light does look interesting though, do you have the specs?
officermartinez
Well, I don't know much about it actually. I am told it has 2100 lumens, has an on-board cooling fan and I believe I was told that it is powered with its own battery system (pretty much just like the SR series from Olight). What I don't know, but very curious to find out, is if this particular light is more similar to a SR95 Ultra Thrower, the standard SR90 or the SR91. In comparison, I've observed the standard SR95 (non Ultra Thrower version) and at initial face value, it seems to be similar in spec(s).
Olight SR95 - Roughly $450. Lumens - 2000. Similar styling to the Powertac Destroyer.
Powertac Destroyer - Quoted MSRP $450. Lumens - 2100. One noticeable difference is the beam selector switch.
Here are the specs that were sent to me. Based on what I've read from the spec sheet, this is probably a pretty heavy hitter of a light..
Destroyer:
The PowerTac Destroyer high-power LED flashlight is designed specifically for outdoor use. The Destroyer provides tremendous illuminating power as it uses a high-efficiency cutting edge LUMINUS SST-90 LED, which can generate a penetrating and perfectly focused 2100 lumen light beam. It uses a magnet-ring switch for changing brightness modes and magnetic contact charging for more convenient and reliable operation. It's portable, yet powerful and delivers on design, performance, quality and reliability. It is the preferred choice of many professionals and ideal for military, police, adventure, hunting, or search and rescue teams. With the Destroyer the user is prepared for any unexpected situations.
Utilizes a cutting edge LUMINUS SST-90 high power LED that enables the Destroyer to produce an amazing 2100 lumens.
Three brightness modes plus strobe feature.
Long 800+ meter beam throw with an impressive flood light to illuminate objects at both long and close distances.
Provides quick access to multiple illumination modes and strobe feature through an intelligently designed interface for tactical and self-defense use.
Features an auto-memorization for direct on / off access to all brightness levels plus strobe.
Offers an intuitive, friendly user interface for effortless operation.
Utilizes a unique digital circuit control technology to maximize battery life and consistent light output performance.
Machined from aircraft grade aluminum.
Maintains its appearance through extreme weather and rugged treatment with a tough, durable Type III anodized finish.
O-ring sealed to IPX-5 water poof standard.
Tempered glass with double-sided coating resists breakage or scratching on impact, maximizes light output.
Adjusts the spotlight and floodlight by rotating the flashlight head.
Battery indicator illuminates around on/off switch when battery life is low.
The charger connector uses a magnetic connection, it is simple to operate and reliable.
Uses a top quality waterproof fan for superior heat dissipation, this feature better protects the LED and electronic components from damage.
Stainless steel rings on both the head and tail cap allows the light to be carried using the included nylon shoulder strap.
Advanced ergonomic design with anti-slip knurling for a firm grip.
Momentary forward click on/off switch for tactical use and better operation.
Specification:
1. LED type: LUMINUS SST-90 LED.
2.Functions: 3 Steady Illumination Levels and Strobe Mode.
Standby Low (Time) Medium (Time) High (Time) Strobe (Time) 0 lm 300 lm (20 hrs) 1200 lm (4 hrs) 2100 lm (1.5 hrs) 2100 lm (4 hrs)
3. Side switch is for power on / off. Rotatable Magnetic-ring switch is for adjusting brightness levels.
4.Battery: Uses 6*18650 (2600 mAh) high quality rechargeable Li-ion battery pack, output voltage is 8V-12.6V, it can be continuously used for about 1.5 hours at the brightest level.
5. Length: 330 mm; Bezel diameter: 76.00 mm; Body diameter: 46.00 mm; Tailcap diameter: 50.00 mm.
6. Weight: 1.2 kgs (not including the Strap and AC Charger).
7. Maximum output power up to 30W.
8. Packing: Portable high strength aluminum box.
9. Accessories: one AC charger, and one high rugged strap.
Head Magnetic-ring switch On/Off switch Battery tube Stainless steel ring Tail cap
Instruction:
1. Destroyer installation is done by removing the head, screwing down the head and body, tighten the unit until it's completely closed, then press the side switch to turn it on or off.
2. To switch functions, turn the light on by pressing the forward click on/off switch, then turn the magnet-ring switch left or right, from left to right the modes will change through Standby
– Low – Medium – High – Strobe .3. To turn the flashlight off, push the side switch to click. When turned back on, the flashlight will access the mode last used. Once turned off, simply tap the side switch and the light will directly go to a momentary ON switching function.
Disclaimer:
After long periods of use on the highest setting, the surface area may get hot. Please use caution when using the flashlight in a constant high brightness level. It is recommended to let the flashlight cool down to prevent any injury.
High intensity light is harmful to human eyes. This product is not meant to be handled by children under the age of 18 without adult supervision.
PowerTac's liability is voided if the light is not used in a proper manner or if modified.
PowerTac reserves the right to change the design and/or specifications of all PowerTac products without prior notice.
Do not throw the flashlight into a fire as an explosion may occur.
Warranty:
All PowerTac products are covered by a standard no hassle lifetime warranty; feel free to contact our office with any questions or concerns.
CouldUseALight
Thanks for the info! Looks interesting...
I wish that pic had some scale. I can never how tell large lights are from pics; I was shocked at the size of the SR95 irl...:eek:
Does anyone have experience with PowerTac products?
Never seen a flashlight form factor (as opposed to something with a handle) that had an active cooling fan. That could vastly expand the host possibilities...
(I was once arrested by an Officer Martinez; guy turned out to be surprisingly athletic. Cheers! :wave:)
Bwolcott
California
yes I own two powertac lights the t1c and the gladiator
Bwolcott
California
Destroyer:
Specification:
Instruction:
Disclaimer:
Warranty:
specs look pretty good but I think powertac needs to work on their pricing since they are relatively unknown
CouldUseALight
It's weird, the other PowerTac lights appear to be standard Yineng Holdings offerings, TN30, TN31, etc....
And then there's this light, with the battery pack and the fan. Yineng doesn't make anything with a battery pack. :confused:
This is out of left field; seems to be coming from the Olight quadrant rather than the DX quadrant, which fits with what Bwolcott said.
I would like to see more designs from the Olight direction, altho I personally will stick with interchangeable batteries. :thumbsup:
officermartinez
What I find interesting is, I am told it can remain on the HIGH setting from a full charge all the way until the battery expires without the unit overheating or going into a protection mode and dimming the light automatically. Hmmmmm! That would come in handy for any prolonged searches without intermittently turning the light ON and OFF due to overheating concerns.
Bwolcott
California
makes sense considering its massive size it should dissipate heat better then some of the smaller 2000 plus lumen lights
CouldUseALight
This has actually got me wondering why nobody else has mounted a fan in a flashlight chassis. :thinking:
Lord knows some of them are large enough and a quick search reveals that waterproof fans don't seem particularly expensive or demanding to feed.
It seems it would rule out immersion, but I'd never submerge any of my lights anyway.... think of the RUNTIME
