I was fortunate to find the one with the head (leavingA), very curious, used to share with KL6 production version approximate.
Head no lettering, for the timebeing there is no way to find it is designed only by virtue of self-analysisand judgment to speculate that it's life experience.
My guess:
1, due to good compatibilitywith L6 Flashlight is possible prototype design one of KL6;
2, assembly and KL6 verysimilar, possible prototype design one of KL6;
3, the LEDs of thespecifications and KL6 very similar, possible prototype design one of KL6;
4, the The spot with KL6 verysimilar, possible prototype design one of KL6;
5 KL6 heat large, in order to beable to respond well in the initial design, you must leave enough space forheat dissipation, designed many fins, which are in the early stage prototypingusing in many SF lamp design, possible prototype design one ofKL6;
6, two head the maidservantsshape consistent, possible prototype design oneof KL6;
7, the head of the circuitmounting screws "" shape, mass production KL6 head is the shape ofthe "cross" possible possibleprototype design one of KL6;
8, positive and negative springis fully consistent, possible prototype designone of KL6;
9, the color temperature thanquantity production KL6 slightly lower (blue) ,possibleprototype design one of KL6;
10, brightness infer theproduction version KL6 higher, prototyping may pursue higher limit productionin order to ensure the use of time and quality, reduce the brightness, possible prototype design one of KL6.
To sum up, I mean very clear, itis 95% likely production version KL6 the prototyping.
I hope you correct.
Brian
1 Left:KL6,right:A head
2 Left:KL6,Right:A head
3 Left:L6+A head,Right:L6+KL6
4 On:L6+A head,Under:L6+KL6
5 Left:L6+KL6,Right:L6+A head
Thank you for viewing
My guess:
I hope you correct.
Brian
