Help! Find a way to cut the cost of this as much as possible.
Cheapest way to do a 1 to 2 square feet array of LED's.
I am doing some scientific experiments that require me build a very bright, thin, even backlight strobe illumination device.
I will be needing the following:
- Even lighting. (Diffuser cover)
- Spread over two square foot
- Very shallow depth (2" or less, thinner the better).
- Can't use few light bulbs, need even lighting over many LED's
- As much wattage as possible
- At least 150 watts minimum per square feet
- Strobe speed capability (1/10,000second illumination)
- Other forms of lights (CFL) is too slow. LED is fast enough.
- I need row illumination capability, light up one row at a time. Need at least 16 independent rows
- approx 6500K (+/- 500K)
- approx 80 CRI
- I will build the circuit myself
- I will build the enclosure myself
- I don't need column illumination capability (don't need expensive dot matrix)
How to do this as cheaply as possible, without too much excess soldering?
The cheapest "easy" method I've discovered so far:
Search keyword "LED ribbon". These are found cheaply off places like Alibaba, eBay, Google that goes as little as 25 cents a watt (On eBay, they are available for as little as $11 for a 5 meter roll of 600 LED 50 watts). I've since found that these are available in 6mm widths, and I've found out I can squeeze 240 watts in a rectangle that is 288 millimeters by 500 millimeters. The 6mm width of ribbon, 120 LED per meter, 10 watts per meter, means I can squeeze 48 rows of 5 watt segments (0.5 meter) for a total of 240 watts. That requires 24 meters of ribbon, or about 5 reels of 5 meters, and each reel is $11 each off eBay, for a total price of $55. But CRI of these are only 65 to 70 for many of these.
However, my main catch is that I need neutral lighting, which is 6500K and 80 CRI. For some sources, that dramatically raises the price by 4x or more by some places.
Know the cheapest way to solve this scientific problem, while still getting 6500K (+/- 500K) and 80+ CRI?
- approx 80 CRI
