SOLD
Up for sale is a Black FM3H turbo head mounted on a custom cut section of mag ,
including FM1909 lamp & FM bi-pin socket and brass adaptor to mag D tube directly for heat dissipation & reduced resistance.
Mag D switch modified to reduce resistance & handle high current
It is powered by 3x18650 in a custom hand-made Elephant body.
3x18650 battery carrier is modified to 3S from 3P & 20AWG wires was used to reduce resistance by shorting the contact points & contact springs so that it can handle high current.
The color and style of elephant body matches FM3H head perfectly.
It use a FM 3" custom OP reflector with cam & I cut the cam off so it'll work with the brass socket holder.
Very smooth beam & throw like mad, the 1909 bulb spec is 2000 lumens
Very smooth beam & throw like mad, smooth beam, homogenious tint & perfect 100 CRI.
The beam shots below are both manual 1" exposure, F3.3 & ISO 200.
FM 1909 in 3" Turbo head:
Reduced exposure indoor shot to show the nice beam:
Asking only $349 $325 ************* Final Reduction $275
Shipping in USA $14
Turn key, you just need add batteries.
Also, I have a 1185 bulb laying somewhere, I will add the 1185 bulb in for free if I can find it.
Shipping in USA $14
