[ QUOTE ]
Spango said:
Someone mentioned the
pros & cons of L4, so I'd like to discuss the pros & cons of the L1 as well. I think the plus point of the L1 is the two level of brightness. Is that really useful? Is the low light dim enough, and the 'high beam' bright enough? Thanks!
[/ QUOTE ]
Hi Spango,
I have been working on my EDC for quite a while and have settled on the SF M2 + SF L1. This gives me three levels of brightness and meets my requirements for bright light, good task lighting as well as long runtime light. It also allows all my lights to use the same spare batteries.
The L1 replaces an E1 + KL1. This combo basically gives me the same light as the L1 on high but in a smaller package. While I really like the E1 + KL1, I like the L1 a lot better.
It turns out that even though I have the M2 on me, 95% of the time (or more) I pull out the L1.
I use both the high mode and the low mode of the L1 fairly often. I tend to use low mode a lot indoors and for navigation and move to high mode when I'm outdoors trying to keep an eye on the dogs in the yard.
In high mode it is pretty good, but doesn't have the throw of the M2 of course. There are times I wish I had a bit more throw or a bit brighter light, but for those cases I have the M2.
All in all I find the two mode very handy. Even better would be a 5W 2x123A light with three modes, covering the same outputs I have now. I'm not holding my breath.
The only thing that could be improved is the size. While not large, I think this light could be smaller.
-john
