Good temporary way to optically decrease brightness of your flashlight?
yohandsome
If your flashlights modes are a tad too bright, perhaps you want a moonlight mode or a lower brightness medium mode, what would be the way to achieve that?
Could you use some kind of semi transparent material and stick it to the glass? What'd work well?
AnAppleSnail
South Hill, VA
To make the smallest change in beam pattern, make yourself a series of pinhole filters. Small dots spread over the face of an opaque object on the flashlight lets you get VERY low output without greatly changing the relative throw. You'll need to use something opaque like foil. Most plastics aren't opaque enough. This gets you ludicrously dim outputs with 1-10 small holes.
Norm
Retired Administrator
Australia
If it's just temporary, I put my fingers over the lens and let some light shine through.
Norm
yohandsome
Norm: Temporary might be the wrong word, reversible is better. Something that'll attach to the glass/front of the light.
Applesnail: I was looking for a thank you button but didn't find one, so thanks! Sounds like exactly what I need. So I imagine thick alu foil could work well for this?
AnAppleSnail
South Hill, VA
Yes. I'm on a trip now, but I made a mockup with a gum wrapper and a chapstick cap. There is a slight 'speckling' effect if your holes are larger than optimal, but it works.
RAM2
Central Coast, Ca
[QUOTE=If it's just temporary, I put my fingers over the lens and let some light shine through.[/QUOTE
Norm's digital filter gets my vote.:thumbsup:
bbrins
MD
Norm
This works pretty good as long as you aren't carrying a Wicked Lasers Torch or something like that.:D
I do this occasionally if I need to get around in the dark house late at night and don't want to wake anybody.
ElectronGuru
Oregon
There's a tint changing thread, with color circles (add yellow to make less blue). The same technique should work with tint. Flashlight sunglasses.
tam17
Wrap my fingers around the bezel. Infinite brightness control, NAV-friendly and works even with a single-mode 500lm F/L;)
Cheers
eh4
Obscuring the lens somehow seems to be the winning proposition, whether foil or finger.
The finger method is especially useful when you want a moon light mode and aren't completely certain that the light is set to turn on at the right low mode.
PCC
Sitting' on the dock o' The Bay...
A variation on Norm's finger method, I ball my fist around the head of the light, obscuring as much as I can then slowly open my fist to allow just as much light as I need out. The great thing about methods that use your fingers or hands is that you always have them available with you and you never have to try to remember bringing them along with you.
If you are hell bent on using an add-on to dim your lights then how about inexpensive neutral density lenses as used in photography? They come in more than a few different sizes and aren't that expensive if purchased on that online auction site.
yohandsome
I need to hold the light at the back, so I can't use my fingers, can you show me such a lens? :)
enomosiki
Get one of those opaque roll of tape and put it over the bezel. It should lower the output and spread the beam out.
Apply more as needed.
tam17
That. Tape, or better, self-adhesive tint (smoke, whatever) translucent PVC film. Cut to required diameter and store inside the flashlight.
Cheers
greatscoot
I have used a waterbottle cap for an "E" series size bezel. Fits perfect and is a great diffuser to. You can also tint them with a marker.
