Klarus
Results 1 to 16 of 16
Thread: Jetbeam switch acting up!
    Flashaholic Megatrowned's Avatar
    Jun 2012
    Wisconsin
    Unhappy Jetbeam switch acting up!
    So I have a RRT-0 I have been EDCing for at least a year. It has been a wonderful light and until now has given me no problems. But just last night I noticed this. As I press the switch (past the point of clicking, kinda like "bottoming it out") it gets brighter! Then when I let go of the switch, it dims down again! What gives?
    This is especially noticeable when using a Enloop. Still does it on a cr123, but not as noticeable. Is it time for a new switch? Note: both batt were good when this happened. Wasn't a lo batt.
    Also, while I'm asking, this light has always flickered ever so slightly while on whenever I used a rechargeable LiOn (not on primaries). Anyone know why?
    Thanks,
    Austin
    Edit: if this is a sw prob., how do I get it out?
    Welcome to the Dark Side! Which just also happens to be the Light Side.
    Jun 2012
    Wisconsin
    Default Re: Jetbeam switch acting up!
    Any ideas anyone?
    Flashaholic* skyfire's Avatar
    Dec 2009
    Los Angeles
    i think ive experienced a similar problem with an older rtt-0 r2 version.
    when i click it, it comes on, but when i release the switch the light flickers and dies...
    i realized i had to tightened the bezel more, so it could be the contact points? try cleaning it up, and make sure the bezel is tightened up well.
    When you've isolated the switch as a culprit, you can try to apply some contact cleaner for fine electronics inside the switch, and do some clicking afterwards (battery removed first). Quality contact cleaners are plastic & rubber-friendly. (Never use WD40 or similar!!!)
    And, just in case, order the new switch. Jetbeam ones are notorious for their short lifespan.
    Cheers
    Flashaholic* SimulatedZero's Avatar
    Nov 2011
    SouthEast, USA
    I will agree that Jetbeam has some dodgey switches in their line up but, I don't think that's the problem here. I had the exact same issue with another light of mine and found that the retaining was loose, again... You can, and should, clean your switch for maintenance purposes but, I think that tightening the retaining ring will solve all of your problems.
    "Maybe you should just stick to fire on a stick... it's received excellent reviews here - plus it's a time tested design..."
    Jun 2012
    Wisconsin
    Quote Originally Posted by SimulatedZero View Post
    Do you mean for the switch? I've been wondering how to get it out...
    Jun 2012
    Wisconsin
    Thanks for all the replies
    Nov 2011
    SouthEast, USA
    Quote Originally Posted by Megatrowned View Post
    The easiest way I found is to use a pair of needle nose pliers that has fairly thin tips so they fit in the notches inside your tailcap. I don't know whether or not JetBeam uses reversed threading on their switches so just use trial and error to figure out which way it tightens and loosens. If you don't have a pair of needle nose pliers that will fit, you can always use a fork and bend the prongs until you get the shape you need. Just tighten the ring down until you can't turn it anymore and that should solve any connection issues that you've been having. Also, if you want to take the switch out and clean everything down and put it back together, that would be helpful too.
    Oh, and if you decide to use a fork, use one hat you won't get in trouble for bending. Your wife/girlfriend might have a thing or two to say about the re-purposing of her silverware
    Last edited by SimulatedZero; 10-25-2012 at 07:22 AM. Reason: So many typo's, I really need to not post while at work in the middle of the night
    Jun 2012
    Wisconsin
    Thanks for the info. Going to try this. And our silverware is only a wedding gift, no harm in using that, right?
    Apr 2010
    Sweden
    No harm at all!
    Just tell your wife it's an important task as fixing a flashlight.
    She will understand. (or not)
    Jun 2012
    Wisconsin
    Ok, so I found a pair of tiny needle nose pliers. The silverware has been spared, this time... Jetbeam has some wierd curved notches on the retaining ring around the tail cap (they must have a special tool for this). With much pressure and force, it came off!
    I removed the switch, and the more I looked at it, the more it reminded me of a McClickie. So I borrowed one from another light, and...I fits! Perfectly! Going to be ordering one for this light.
    Thanks all
    Banned
    Jul 2009
    Maryland, Near DC, USA
    Sounds like the switch was just loose. If you look at the design of the switch, when you press down on it, you also press the metal contact against the inside of the battery tube. When you release, it can lose contact if it isn't tightened properly.
    By the way, tightening the retaining ring does nothing to secure the switch itself. The retaining ring only secures the silicone cover. The switch must be tightened separately.
    Nov 2011
    SouthEast, USA
    Quote Originally Posted by fyrstormer View Post
    In my experience, I have found that tightening the retaining ring fixes what ever contact issues I was having with the switch.
    Thanks all
    No problem at all Megatrowned, hope everything works out well with the new switch.
    Banned
    Jul 2009
    Tightening the retaining ring will press the switch into place if it is very slightly loose, but that's all. If this is something you have to do from time to time, removing the retaining ring and tightening the switch itself should put a stop to the problem for much longer.
    Oct 2007
    Sitting' on the dock o' The Bay...
    Have you seen this thread?
    Jun 2012
    Wisconsin
    Thanks for the link. Since a McClickie fits, I'm just going to stick one in. Really can't top it (a "silent" version would be cool though). Plus, telling a non-flashaholic that it has a "McClickie" in it just sounds cool
