GPB
I just picked up the Terralux 1000 lumen drop in for a 4 - 6 cell maglite. Terralux quotes the run times as 2/6/37 hours on High/Med/Low. I assume they're quoting times on a 6 cell set up rather than 4. I am using 2 adapters that allow you to run 3xAA in a D size format so I can use this is a 2 x D cell Maglite. So what I'm wondering is if this thing runs for 2 hours on 6 D cells, how long will it run on 6 AA cells ? Either NiMH, Alkaline or LIthium. ( I happen to be using the second tier Lithium cells ( not the best ones, but hopefully better than Alkaline )
Thanks !!
Thanks !!
