Robert_M
I just got my M61SHO a few days ago. I was expecting more full output run time on primaries.
Thanks for posting! How much heat did you notice with the 2xCR123 cells? Have a reference to describe to like an M60 or M61?
The item that may be a closer fit to your runtime goal is the M61 - I expect that it will be upgraded for the XPG-2 at some point, meeting your runtime needs.I wish a more sensible driver had been used for this module. 30 minutes at 1A draw is rediculous. It should be 75+.
The [M61] full output runtime is approximately 2 hours on two CR123 primary batteries [...]
I have an m61 and find it completely inadequate compared to my surefire m600c. It's like if my m600c had a moon mode with crappy tint.The item that may be a closer fit to your runtime goal is the M61 - I expect that it will be upgraded for the XPG-2 at some point, meeting your runtime needs.
The funny thing is that when the M61 first came out, it was criticized by some for being not driven as hard as some would like.
I think that most folks would be happy with the two choices at present: an efficient M61 and a hard-driven M61SHO. :shrug:
There is more competition for top-quality high output dropins these days - IMO it's a good idea to have a few different output choices for each Malkoff line.
Your runtime one two CR123 primaries seems a lot different from my personal tests with the M61SHO. I am going to run another test with some Battery Station Primaries. I will respond here with the results I get and will revise the specs on the SHO if necessary. I appreciate the input.
Indeed for the guy who uses an M61SHO with rechargeables as well, a 3xCR123 setup is more likely to be used as backup since I'm guessing that such a person will be using a minimum of 2x17500 or larger, requiring a 3-cell body length for better runtimes on full output. Thought I read somewhere that the SHO outputs too little light when used on low (high/low ring) and 2x li-ions. Maybe I got mixed up with the standard M61 here.
M61 SHO works just fine on low with 2 x CR123. The regular M61 output on low is noticeably lower on a single 18650 vs 2 x CR123 but still usable in my experience.
I have performed some testing of my own and have revised the specs as noted below and on the website. My initial testing was performed with a power supply.
This testing was performed using Battery Station primaries. The old numbers are correct.....for a power supply. For some reason, in my original zeal, I failed to consider that the batteries would somewhat choke at the high current. These numbers are much more conservative and a realistic appraisal for battery (real world) powered operation. I apologize if anyone feels mislead as this was not my intention.
The output of the dropin is approximately 385 measured out the front lumens. Your output may vary according to lens/bezel configuration. The current draw is 1000ma at 6 volts. The full output runtime is approximately 45 minutes on two CR123 primary batteries with a long taper as voltage drops. On three cells the full output runtime is approximately 1.25 hrs with a long taper. On four cells the full output runtime is approximately 2 hours with a long taper.
Thanks,
Gene Malkoff
