Dan C
Just whipped this up tonight. I made a new head assembly for an Infinity body which utilizes a MadMax sandwich and full-length NX05 optic that has been reduced in diameter to .560". The head was bored from the rear, leaving a small lip at the front for the optic to bear against, then a separate part was press-fitted in to position the optic and provide a ground for the sandwich. The beam looks just like the Firefly or any other typical LD light and is surprisingly bright for one AA. Next up is to shorten, bore and re-thread the body to take a CR2 batt..
Dan C
Dan C
