Okay, so after a little more research into what I would like to do- I'd like to make a combined night dive light, and camera video/focus light. What I know and have built with before in aquarium lighting is cree 3 watt 20mm stars. Would those be applicable here?
This is what I would like to do (I'll be making a custom aluminum enclosure for these)
Three 5-watt Cree 5-Watt XM-L stars MAx 3000mA, about 5000K, ~2.9v forward voltage each. Not sure how many lumens this would be, but aiming for about 1,000 to 1,200
Along with those, I'd like to run three 3-watt RED XP-E led's, MAX 700mA ~2.4v forward voltage (these I'd like on a separate switch, for funding critters at night, as they don't see the red...)
Ideally the 5-watt Cree white LED's would be on a dimmer, or somehow control their brightness. I would do this on a potentiometer normally running AC power, but not sure what options there are with batteries, or if they are the same.
If I were doing this with AC power it would be no problem, but with batteries- not sure what to do. What rechargeable batteries would you suggest, in what configuration?
I saw these
http://www.all-battery.com/asizenimh2500mahrechargeablebatteries.aspx
Which are 1.2V and 2500mA, so does that mean I would need about 6 to run the 3 CREE's above, slightly under driving them?
I could probably put the 3 red LED's on another circuit, as I need to drive them at significantly lower amperage- do I need a different battery whose output is 700mA? I think I might be missing some fundamental formula for calculating what I need
Help?
Thanks, Peter
