I had a couple of questions about the Maelstrom MM-X.
1. Are there difference between the Maelstrom X7 and the MM-X? or are they identical?
2. How does the throw of the MM-X/X7 compare to that of the quark 1232 and the quark turbo 1232? I imagine the throw will be better then the quark 1232 but worse then the turbo?
I could not find any details on the MM-X vs. X7 issue, nor could I find side by side beam-shots of the Turbo vs. the MM-X, so I figure I would lean on every-bodies experience.
Thanks
Thanks
