Hi All. I tried doing a search on this first, but am not having any success.
As the title indicates, my old school L4 finally gave up the ghost. Can I get the lamp repaired, or do I need to replace the whole L4 head? Thanks in advance.
Modding sounds premature since you don't know if the problem is a dead driver, dead LED, or dead batteries.
I suggest that you call Surefire and explain the situation to them. I imagine they would give you a RMA to send the light back for them to either repair or replace the head. If then you wanted to have it modded, you would at least have a functional head for a modder to work with.Batteries were replaced with fresh ones. The contact where the bottom of the head meets the battery seems to have torn away from the black plastic that surrounds it, so there is no contact being made with the top of the battery.
....That is some serious customer service.
:twothumbs
Did you send back the non-working one? If not have it modded.
