Sold/Expired Arc First Run Triple Nichia 219 **SOLD**
F250XLT
CA
This one was built for me by DatiLED, here are the specifics per Derek...
"The Arc triple has three Nichia 219 LEDs in parallel, driven by an AMC 3-level regulator board. The optic is a Carlco 10507 narrow array. The heatsink is a solid piece of turned aluminum that contacts the inside of the head for good heat dissipation."
$250 Shipped to US address, Int'l available.
:Sold:
F250XLT
CA
Re: Arc First Run Triple Nichia 219
Unfortunately, no...I'd have to get that estimate from Derek.
datiLED
Atlanta, GA
Any idea about the runtime ?
Using a quality 750mAh RCR cell, 70mA should give at least 11 hours of runtime, 420mA should give at least 90 minutes of runtime, and 1400mA should give a little more than 20 minutes. This is based on cell capacity and current drain, with some fudge factor applied. I think that the light would get pretty hot after 20 minutes on high. The heatsink is massive, but the light is small. That is a lot of heat to dissipate. I only tested the high level for 10 minutes, or so. It got warm, but I was holding the light with a full hand grip.
The light can use any RCR cell, and IMR's are recommended. The levels are set at 70mA, 420mA and 1400mA. (5, 30 and 100%) BTW, it is the 1400mA driver board from Illumination Supply.
moshow9
El Paso
Arrived today and...... This is an awesome light! Thank you Tim!! :)
