What voltage does the LED use (or is that not decided on yet and can be 6/9/36 depending on driver)?
What batteries do you plan to use (some sort of estimate of size/configuration is at lest needed)?
Without knowing that stuff we can't help you much, for all I know you want to run the 36 volt off a 600 volt AC source.
