martynball
- Joined
- Nov 15, 2012
- Messages
- 3
Hey guys, quick question. My logic says that there will be a big difference in the brightness of these two torches, but thought i'd ask just in-case.
My usage?
I work in security and just want the brightest torch I can find, but at the sorta size that the two torches in question are, and also don't want the price going above £20.
Also want it sort of stylish, I prefer the look of the 800LM Lumen CREE R5.
800LM Lumen CREE R5 LED Zoomable Adjustable Focus Aluminum Flashlight Torch
Material:6061T Durable Aluminum .
Model No.: UO-A1R5
Max output : 800 lumens (MAX)
Lifetime-above 10,000hrs
Operate Voltage: 4.2 V
Bulb:Super Bright CREE R5
Save 40% power compare with Xenon and Luxeon Bulb.
adjustable focus range for different usage
Zoom: x1
x250
x500
x1000
x2000
3-mode adjustable Brightness,High/Low/Strobe
Super Bright, blinding Effect
"O" ring sealed, Waterproof, can be used in rainy weather (Don't put it into the water).
The ON/OFF push button switch is provided in the end cap.
Water resistant.
Body Color: Black
Size(mm) :143mm(Length)x36mm(Head)x28mm(Body diameter)
Battery Type:1x18650 or 3xAAA (not included any battery)
Suitable for Self Safety, hunting, cycling, climbing, camping and outdoor activity
BORUIT CREE XM-L XML T6 LED 1200 LUMEN 18650 ZOOMABLE FLASHLIGHT TORCH Z17
Which is better? Or any other recommendations?
See Rule #3 Do not Hot Link images. Please host on an image site, Imageshack or similar and repost – Thanks Norm
My usage?
Model No.: UO-A1R5
Zoom: x1
x250
x500
x1000
x2000
Water resistant.
Body Color: Black
- 100% BRAND NEW
- Type of LED : CREE XM-L T6 LED
- Adjustable Focus : Can adjust its focus for different usage .
- Output brightness : Can come to above 1200 lumens [lm]
- Internal wiring applies the high efficient booster circuit, working voltage is wide and can utilize the
- batteries in the largest extent.
- Waterproofing design
- Material: High quality 6061T Aluminium.
- Switch: Press Tail-cap on/off
- Mode: high / middle / low / strobe / sos / Zoom in & Zoom out
- Power by : 1x 18650 (Not Included)
- Size : 125mm x 32mm(Head Dia)/24mm(body)
- Weight : 90g
- Colour : Black
