I have two Solarforce L2M hosts that I have not put a drop-in into.
What real role would Solarforce L2Ms with High Lumen LEDs have in a real world situation with little cooling?
I added two more graphs showing the run time with NO fan. The last 3 graphs are of the same module (Smooth, 2 level, 2.8A). There's very little difference between the graphs when plotted up to 62 minutes; the fan has little impact on the run time graph. The L2T Head gets quite warm at 144F (62C). The body is only slightly cooler at 139F (59C).
The data below is with NO fan. An IR temperature sensor was used.
Elapsed Time, Minutes_____Head Temp, F (C)______Body Temp, F (C)
8_____________________114 (46)______________n/a
15____________________132 (56)______________n/a
30____________________144 (62)______________139 (59)
45____________________136 (58)______________130 (54)
60____________________129 (54)______________122 (50)
75____________________118 (48)______________112 (44)
90____________________107 (42)______________103 (39)
