Hmm, looks like I'll need to do more reading. Still new to lights and electronics in general. Any links about how the grounding works?
I want to try and build a light and have 2 modes but switched by twisting the head (like a tk11), has anyone done this?
EDIT:
So from reading, I should ground the + end of the led to the outer copper ring on a board. There for when tightened, it will be HIGH mode only.
Then I should make the threads/pill connected normally (so it does not bypass the microprocessor).
So when tightened and there is contact with the copper edge on the driver, it will bypass the microprocessors but not any regulation. Then when loosened, the current will go through the threads and go through the microprocessor (which I somehow set to a lower output).
