I have several of these lights. They're made by a automotive tool manufacturer called Uview. They're very well made and rugged, but somewhat anemic. Uview has a newer version that replaces the 30 LED panel with 3 100lm Luxeon units.
I'd like to modify the one's I have and get a bit more performance out of them- I would appreciate any ideas or suggestions.
The tube bodies are 1" ID polycarbonate which measures out to 25.5mm. OAL is 11.5". Current battery is a 12-pack of AAA NiMH marked 14.4v/600 mAh. In the base there's a barrel plug for charger attachment and a micro toggle switch rated at 5A@125VAC. I have approx. 3/16" extra space in the base and over an inch above the LED array so there's plenty of room for a little longer battery and a driver.
On the battery side, there's room (I think) to fit a 25650 battery inside. If necessary I can open the tube up a little. An 18650 would be an option, but I hate to sacrifice the additional runtime. I was considering using a copper strip arrangement to get current up to the LED's from the switch in the base if I can get the 25mm battery to work.
I understand that the polycarbonate is going to be a limiting factor thermally- plus being a work light, I'd like to retain some level of practicality which means a reasonable amount of battery life.
My thinking is to use a piece of 1" dia. aluminum bar stock and mill a flat/channel in the face and mount the LED's there. There's about 3" of open tube where the existing array resides. I'm thinking either three or maybe six LED's in that space arranged in a line. If I could, I'd like to get around 600lm out of it. I'm thinking the tube's inability to conduct heat will become an issue above that point- or maybe even less.
Would six units be better than three for even distribution of light?
What are the opinions on the thermal issue?
What suggestions on LED's to use? I'd prefer a warm white with a high CRI if possible.
I'm open to any suggestions. What's written above are only my beginning thoughts. I'm not married to any of my ideas.
Thanks for any and all assistance!
