Wangstang
For the last two years I've been trying to get my hands on an affordable and durable Surefire M-Series weapon light LED conversion option which could continue to grow as LED's improve. TNVC has been selling a third party(TLS) product for a few years but it did not use the CREE XML and it does not have the ability to be upgraded for a small cost as LED's continue to mature. The Surefire LED module is well over $200 and again, the Surefire option can't grow with the technology.
I put out a few feelers to a some of the more reputable manufactures in the last year and most only wanted to come up with a drop in LED bulb assembly that would be a compromise design which would work in the Surefire bezel which would cost about $100 and would still not fully utilize the reflector.
I finally was able to reach Mark, the owner of Lumens Factory, and he agreed to take on the project with the intentions of designing a complete conversion head for under $100 and could be upgraded in the future for about half of the cost of a complete new conversion head.
Here's what Mark came up with using my input:
You can take a look at the full website here:
http://www.lumensfactory.com/mini_turbo_head.php
As LED's continue to improve Mark will be offering new drop in modules for the head assembly so you'll be able to keep the lamp module up to date without having to buy the entire assembly each time.
So here's a set of comparison photos shot at the same ISO and F stop settings from the same position:
The control with no light
The factory Surefire Incan
The Lumens Factory Single Mode
The Lumens Factory 3 Mode Low
The Lumens Factory 3 Mode Medium
The Lumens Factory 3 Mode High
To cycle through the three modes I squeezed and released the pressure switch on my weapon lights.
I put a few hundred rounds down range with the single mode and the three mode modules. I did not have any problems with the light system while firing or after firing. I also did some drop tests and had no problems.
Enjoy,
Wes
PS: While I helped develop this product I am not an employee of Lumens Factory and I will not be getting paid or earning any royalties from this product. I work in the LE field and I worked with Mark to develop this product because I, along with several of my co-workers, were in need of some modern light upgrade options at an affordable price. Getting an affordable product on the market that will help me and my co-workers is payment enough!
· Material used for the bezel body: 7075-T6 Aerospace Grade Aluminum
· Coating used for the bezel body: Mil-Spec HA3, Tactical Flat Black
· Lens: Extra Thick 4mm High Temperature Resistant Tempered Glass Lens
· Module completely potted with 3M potting material and 3M heat dissipating products.
· Improved Thickness Dual Contact Springs
· Total Weight: 71g (Head Unit with Module)
· Run Time on 3 x CR123a Primary Cells: 60 minutes on full output continuous.
· Compatible with Surefire® 1.62" Diffuser, Lens Cover, and Filters.
Enjoy,
Wes
