Oztorchfreak
Nitecore TM11 V3 has to be screwed up "VERY" tight for light to work. Anyone else?
Hi Guys.
My new Nitecore TM11 V3 (V1.12-1111) Tiny Monster head and battery tube (Body) has to be screwed together "VERY TIGHTLY" to get the light to come on.
I think that the amount of force needed to connect both parts together is "FAR TOO MUCH" than should be necessary on any flashlight.
I do not think there would be much pressure holding these two parts together and I don't think this light would therefore be making a really good connection as well.
I have tried many batteries with this flashlight.
I have tried many "Brands and Style of tops" (Raised Button and Nipple Top) and none of them make a really good contact to turn the light on without "BRUTE STRENGTH!!"
I have tried many older batteries and the newer 3400mah (Panasonic Type) batteries.
The length of all of these batteries is pretty close to each other as measured by me.
When they are inserted into this light they all have the same problem.
I have concluded that the TM11 V3 at least, should have the been designed with the battery holder (Body) of the light longer and have used a better longer spring arrangement as the plate at the bottom with it's "springy tabs" does not allow any more than about 2mm to be completely bottomed out.
I probably will see if there is another TM11 V3 back at my Dealer to compare it with.
The Skyray King does not usually have this issue, as I have bought around 12 now for myself and to give to family or friends.
The Skyray King has "very long coiled springs" that let the batteries settle in no matter what length they are and the batteries "bottom out" at around 6mm of travel into the battery tube, much more travel than the TM11 will allow.
The Skyray King allows for longer batteries than what the TM11 does!
Is there anyone else that thinks they have the same thing happening with their TM11?
Is it just something that has changed in the newer V3 version (V1.12-1111)?
Maybe it is just my TM11 V3 that has this problem! :thinking:
CHEERS
Hi Guys.
CHEERS
