Sold/Expired FS OR 6P HA Nat Bored, Quad XP-G & FETtie switch SOLD, Aeon sold
nfetterly
Cincinnati area, but lots of travel
6P HAIII Natural, Bored for 18mm cells, gold bezel ring (can switch out). No tail switch at this time. QUAD NOT INCLUDED. I can include a drop-in. Leather holster included (no discount if you don't want it).
$125 SHIPPED USA ONLY (can only ship between Dec 30th & Jan 2nd). Priority with DC.
6P setup (Quad NOT included)
Fits all 18650 / 18350 cells that I have. Note - no tail switch included
head shot, holster in background - note - no drop included (although I can probably find one to put in for free)
Hi-CRI 5.6A Quad XP-G with FETtie switch SOLD
custom bodies (to go on sale later)​
Package
  • VanIsleDSM 5.6A Quad (HiCRI XPGs)
  • FETtie high current switch installed
  • Oveready Natural HAIII 6P 18650 bored with smooth gold colored bezel OR
  • TNC Natural HAIII 26650 with cooling bezel and slots for trits in head & tail (brand new, never been used)
L/M/H and ~1500 lumens on high
Specs:
Precision machined to fit genuine surefire and FM26XXX P60 hosts.
Single Li-Ion cell operation for energy density and safety.
LEDs individually current regulated.
Integrated thermal shutdown.
Reverse polarity protection. Upside down battery causes no harm.
2KV ESD protection. Resistant to static shock from your fingers.
Low battery warning (drops to low mode and intermittently flashes off quickly).
Mil-Spec Teflon insulated oxygen free silver plated copper conductors.
Silver plated beryllium copper ground spring with gold plated contact.
Gold plated positive contact.
Cushioned shock resistant driver.
Modified Khatod Italian made 10 degree FWHM (tested with XPE) beam. Tightest beam possible from P60 multi-LED engine. More common Carclo optics pictured for comparison are 16.4 degree FWHM. (Frosted version pictured)
Thermal Data:
C101 99.99% pure oxygen free copper thermal conductivity: 391 W/m · oK
99.9% pure silver plating thermal conductivity: 418 W/m · oK
LEDs directly mounted to silver plated copper surface. No MCPCB insulation layer. Lowest thermal resistance path possible without extremely exotic materials (e.g. diamond)
Information Thread:
https://www.candlepowerforums.com/threads/296127
Introducing the ultimate high power tailcap switch for Z41 and FM26XXX hosts.
Designed as a supplement to the P60 Quad drop-in, This switch's capabilities extend well beyond it's originally intended necessity.
With ANY Linearly regulated or Direct Drive light, this will reclaim power currently being eaten by your higher resistance switch/spring, and give you more current, and more lumens.
With ANY Buck, Boost, or Buck-Boost regulators, this will reclaim power currently being eaten by your higher resistance switch/spring, and provide longer runtimes.
How does it work?
The FETtie uses a solid state semiconductor, a MOSFET. Essentially a relay, with no moving parts, which is turned on by the clicky switch. The Clicky switch itself only conducts 100 nanoamps, that's 0.0000001A, to activate the semiconductor. This means the clicking mechanism will last nearly forever, as the electrodes will not wear from arcing.
The FETtie uses a small coin battery, 1216 size. You do not need to worry about this battery becoming depleated however. It's like the battery in a watch, it will last for many years. Even being left on, the switch will draw less current from the coin cell than it's self discharge rate
Specifications:
Current - 25A+
Voltage - 12V MAX
0.0034 ohm Rds(on) MOSFET resistance
Beryllium copper spring, Pure silver plated for extra conductivity, 24K gold plated contact area.
Gold plated contacts from the FETtie to host.
Threaded brass body
Panasonic 1216 coin cell included
$400 with Oveready 6P HAIII 18650 body and leather clip-on holster with flap
$450 with TNC HAIII 26650 and one never charged MNKE IMR 26650 TNC HOST IS SOLD
TNC body with IMR 26650 (prescription bottle to ship in)
TNC body in it's peices - never been used.
Aeon - Hardcoat Blue - $150 (with 2 new, 1 used CR2s) - SOLD
The ultra-small Aeon is the result of several years of product engineering in an effort to produce the most useful lighting tool for a wide range of uses. A precise execution of practicality, useability, and durability have produced a flashlight small in size, elegant in design, and useful in practice. Only 2.15" by 0.7" small, shorter than your average pack of gum, the Aeon is tiny enough to fit just about anywhere, and since it fits just about anywhere, it will be there to provide illumination when you need it most.
Features
Sapphire Window for Enhanced Strength and Scratch Resistance
Parabolic Reflector for Long Distance Illumination
R2 Flux Bin CREE XR-E XLamp? LED 114 Lumens Minimum Output, 50,000 Hours of Performance, Essentially Indestructible and Never Needs to be Replaced
6061-T6 Aerospace Grade Aluminum Construction with Brass Innards
MilSpec Type III Hard Anodizing (Natural, Black, and Blue)
Chemkote Interior for Enhanced Corrosion Resistance
O-Ring Seals at All Junctions Weatherproof
Gold Plated Circuit Contacts
18.5mm in Diameter by 55mm Short
1.5 Ounces / 43 Grams Weight
Fully Regulated Two-State DC-DC Converter - 1:30 Runtime on High Mode, 40 Hour Runtime on Low Mode off a single CR2. Twist Activation.
Rare (& beautiful) Hardcoat Blue, nice dark blue color.
Comes with a used CR2 installed & 2 new CR2s.
Only selling because I'm getting one in Ti
Please, at this time – USA only.
I'll take it in thread takes precedence over PM communication
Prices are shipped usps priority with DC.
Quad package will be insured
Aeon will not be insured unless you cover it.
Light is yours once in the hands of the USPS
Paypal preferred, timely payment required.
AVService
Re: FS: Quad 5.6A HiCRI XP-G in choice of custom body & FETtie switch, Blue Hardcoat
If the Aeon is available by itself I will take it pending knowing the price?
It is not that clear to me.
Thanks
Ed
jmpaul320
CT, USA
nice items - if you are ever interested in parting out the FETtie switch I would be interested
best of luck with the sale :)
nfetterly
Thanks, but I don't expect to be parting that out. Maybe not quite as rare as hen's teeth, but I don't think I have ever seen one come up by itself on the aftermarket. I've got another setup almost exactly like it, just slightly different LEDs and have yellow trits in the head and green trits in the tail. I wouldn't be selling it if it were my only one. Also have FETtie's on my 5A+ direct drive M2-50 (SST-50 in M2 head - Oveready) and 5A+ direct drive M2-XML (XM-L in M2-head - Oveready, modded a M2-50 head by Tom for me - thanks Tom!)
jaycyu
Vancouver BC Canada
Re: FS: Quad 5.6A HiCRI XP-G in choice of custom body & FETtie switch, Aeon sold
I have some questions:
1) Are you willing to ship to Canada with increased postage?
2) Can you sell the quad and FETtie without the body?
3) Can you confirm this is a copper quad instead of an aluminum one?
nfetterly
Yes
Yes
Yes
I'll take this to PM...
jaycyu
Vancouver BC Canada
I'll take the Quad and Fettie. I'll pm you to sort the paypal details. Thank you.
nfetterly
Re: SOLD Quad 5.6A HiCRI XP-G & FETtie switch, Aeon sold
The Quad/FETtie arrived this morning. Thank you.
Not too bad given Christmas season madness at the post office (s) - national flashlight day too!
The OR 6P Bored HA Natural with gold bezel ring is still available. I do have several other bezel rings if someone wanted it swapped out.
03gixxthou
How much for just the TNC 26650 host and batt shipped US? Thanks!
Sent from my Galaxy Nexus using Tapatalk 2
03gixxthou
No problem, thank you for the quick response!
