10 lumens on lowThank you for the quick reply. What is the low lumen?
If you search the forum, there is a secret low low beam that you can activate.
IIRC both of these outputs were understated, I seem to recall that a high of 100 lumens and a low of 20 lumens were closer to the mark with fresh cells. :shrug:10 lumens on low
I can't seem to find that particular thread at the moment either, but some of these tailswitches may have had a "feature/bug" where additional resistance in the circuit could (temporarily) further reduce the low output....
....My thought is the following thread - from what I understand, L1's don't seem to exhibit this behavior until they have tailcap resistance settings of 20+ ohms instead of the stock 10 ohm tailswitch. :shrug:x2
SureFire L1 tailcap disassembly procedure - changing resistance values
