Mr Happy
I did a search for discussion of Freeplay lights and the most recent thread I found was from 2011.
Having just bought a current edition of the Freeplay Sherpa light I thought I'd make one or two observations for anyone who is interested.
The light easily disassembles by undoing a few screws holding the case together, and inside the construction is rather straightforward and "low tech", making it probable you could repair it if needed.
Given some comments I have read about battery replacement, of most interest to me was finding a standard NiMH battery pack inside of a kind similar to the ones used in cordless phones. It is a 1/3A (?) 3 cell 600 mAh pack with a molex type connector. The battery is surprisingly small, being dwarfed by the size of the light, but I suppose it is sufficient for the job. I am confident the battery could be replaced if required, although I am slightly disappointed not to find conventional AAA or AA cells inside.
I don't know what the LED emitter is, but it gives a decent light, certainly enough for emergencies. At a guess, maybe something like 20 lumens on high and 5 lumens on low. Given such a small battery and long run time it's not going to light up the world.
Mechanically it seems sound. I think it might not survive a big drop, so the claims about it being extremely durable are possibly misplaced, but it looks tough enough for normal use.
The crank mechanism has a smooth feel to it and seems to be reasonably efficient.
If you don't like cranking, you can charge it using a standard USB cable. It apparently takes four hours to fully charge the battery and then it will give many hours of light.
Sadly it doesn't have intelligent charge control, just a reverse protection diode and a few current limiting resistors between the 5 V USB supply and the 3.6 V battery pack. So you must not leave it on charge indefinitely or it will overcharge the battery. Bad marks for that. Should do better.
So anyway, just a few thoughts from a brief examination. Not an extensive use test by any means. However, if you are interested in the idea of an emergency light that doesn't need batteries, this light may sit well alongside other rechargeable lights.
