ToyTank
I'd like to see how people are modifying the beam practical or not:tinfoil:
Some fine CPF members discussing it in this thread gave me the idea to try my own.
Seems the most common complaint is the beam is too tall. I wanted to see if I could shape the top and bottom of the beam without just blocking that light.
I cut 2 pieced from opposite sides of a fresnel lens and jointed them as well as I could on a piece of clear tape then cut to fit on the bezel. I was thinking of what bifocals do and thought i'd start from there. For a test I just taped it on the bezel and gave it a go.
Shameless copy n paste
There are a few things I want to change on the next attempt.
1.Better optical quality lens, new and not scratched up and dirty-No tape over the bezel maybe water based adhesive on the bezel ring.
2.Not cover the whole lens-just a strip on the top and bottom.
3.focus is too strong the spill comes from the opposite side of the lens This should make the shape less acute also
4.Ugly Not real proud of how the first one looks.
I know there are a ton of mods in the main thread. Feel free to post them here!
I was thinking about it so I did a real quick and dirty proof of concept. It took longer to take photos, edit, upload yada yada.
This is with 2 layers of tape and a dirty scratched up old lens with a big ugly joint down the center. Normally IMO you'd want the lens turned 90 degrees for headlamp use, I have it like that for taking the picture only.
IMO with a little polish this would be a nice simple mod:shrug: It works better than the photos show- Cell phone camera
Stock
Proof of concept Zebra eye
Like I said quick, ugly I did not even cut the lens straight
Edit:This is where I cut the lens-top is top. I cut there because I wanted to squish the top and bottom of the beam down. I think it went to far though as you can see in the photo. You really should be able to customize the shape of most light beams. Fresnel lenses historically are used for lanterns and lighthouses not sure why we don't see them more in flashlights.
