Test/Review of UltraFire BRC32600 4000mAh 3.0V (Green-white)
HKJ
Copenhagen, Denmark
[size=+3]UltraFire BRC32600 4000mAh 3.0V (Green-white)[/size]
Official specifications:
  • Voltage: 3.0V
  • Capacity: 4000mAh
  • No PCB protection board included
This is LiFePO4 batteries, this means they are 3.2 volt nominal voltage. This voltage is to low for a typical 1xLiIon flashlight.
The battery has a very flat discharge curve, where voltage depends on current draw, not on how much charge is left in the battery.
This type of battery does not have a protection circuit, because the chemistry is safer.
[size=+3]Conclusion[/size]
The performance is good for a cheap battery, but the capacity is overstated
[size=+3]Notes and links[/size]
How is the test done and how to read the charts
How is a protected LiIon battery constructed
More about button top and flat top batteries
candle lamp
South Korea
Thanks you very much for your excellent test review as always. HKJ!
As you mentioned, this battery is safe although it has no protection circuit. Does it mean LiFePO4 cell is safe in overdischarge without the protection circuit?
HKJ
Copenhagen, Denmark
It will not go :poof:, but it will still damage the battery to over discharge it.
ma_sha1
CT, USA
Thanks for the review, I've been wondering about theses. How hot does it get when doing 20A discharge? Will it maintain capacity at 20A use?
HKJ
Copenhagen, Denmark
I cannot answer either of the questions. I do not have a temperature sensor on the battery when testing it and I do not have enough equipment to test a battery at many cycles (I need my equipment for other tests).
