techwg
With lights like the PD32 etc you can choose what your brightness is going to be each time you turn it on. What do you prefer to have your lights set to? Do you have yours on maximum? 1 down from maximum? Lowest? I am interested in also hearing your reasons for the brightness mode you leave yours on.
I typically leave my lights set to maximum by default and then only turn down if the situation does not require full light. However I have pondered if there is any advantage on using a slightly lower level as the default. Maybe it is more "tactical" to misrepresent the brightness capacity of your light, only to be able to double your lumens at a single push!
Interested in this, I am...
