ToyTank
V2 in Post 2
I have been thinking of this for a while. I know we have all tweaked the legs of a 5mm LED to light it up in our hands(right?) I figure that's the simplest LED light.
LED-Battery-Contacts
I've been using a HCRI 5mm LED on top of a lifepo4 cell for awhile.
Probably not the first to try, I took a WW junk 5mm LED I have and added Magnetic leads onto it.
I'm using solid core 24 AWG nickel coated wire. I salvaged it from the recycle bin at work
To connect leads to the LED I used a wire wrap gun which makes a sound solder free joint. Solder would be fine though.
If you have or plan to use a wrap gun you'll need solid core, you can not wire-wrap stranded.
Then mask the LED with tape and cover the bare wire with liquid tape. /\
Make sure and fill the void between the contacts.
I don't have small enough heat shrink, but I'd like to add some.
After it dries time to add the magnets. Strip 1/4" or so of wire. Form them to the curve of the magnets. Tin them if they are not nickel plated.
Place magnet on steel surface to hold it steady. I used tape to hold wire to surface, then slid magnet up under the wire till they mate.
Make sure Iron is hot and tinned. hold iron on wire past where it meets the magnet and rub your solder between the iron and manget on the wire.
If the above is not clear I can make some photos. Surprising easy soldering thanks to nickel plating on the magnets.
Heat resistant magnets are available but I had no issue.
V1 completed!
Photo is running on 2 eneloops at well under 1ma.(not sure how low) Metered 48ma @3.35v AW IFR16340(not shown)
V1 and V2 running on same eneloops, the V2 can take any 5mm LED easy swap and even fast load modules:naughty:
IR-UV-Blue-any 5mm LED just make sure and use appropriate voltage-
Thanks for looking DIY for V2 in post 2. Half the work and so much more versatility!
V1 completed!
